Hello GID team,
Is there a way to mesh one line at a time?
I use the following
.central.s process escape escape escape escape Meshing MeshCriteria Mesh
Lines $LineNumber
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031126/075a2174/attachment.htm
Can mesh only a line, but cannot generate the whole mesh step by step. When generate a mesh, the previous mesh is deleted.
To mesh only some line, set mesh criteria == NoMesh for the other lines.
for example, to mesh only the lines 3 and 5, can use
.central.s process escape escape escape escape Meshing MeshCriteria NoMesh Lines 1:
.central.s process escape escape escape escape Meshing MeshCriteria Mesh Lines 3 5
Sent: Wednesday, November 26, 2003 3:36 PM
Subject: [GiDlist] meshing one line at a time
Hello GID team,
I use the following
.central.s process escape escape escape escape Meshing MeshCriteria Mesh Lines $LineNumber
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031201/0e37913c/attachment.htm
