another question, can GID create a load vector, i.e. in the *.cnd file I
define a load condition as follows:
condtype: over lines
condmeshtype: over nodes
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
then I assign to one boundary line (l = 1m) of a rectangle this line
load . Does each of this 5 node of the boundary line after meshing get
0.25 kN(inner nodes) / 0.125 (outer nodes)? Or simply 1.0 kN/m? It seem
to be the last one.
Sebastian
It is possible to define condition values that change depending on the x,y
and z coordinates. It would be the typical case for applying a triangular or
parabolic load to a boundary of the model.
To do so, check the type of field #FUNC# in the problem type conditions
help.
About the planar surfaces, they are being completely substituted by the
NURBS surfaces. It is better to use these.
ccondtype: over lines
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
to be the last one.
Sebastian
Numèrics en Enginyeria
C/ Gran Capitan s/n,
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
to be the last one.
yes you can,
The way I used to define the force vector is as follow:
in the .cdn file you can add a condition of point-load or face-load
as you mentioned above with whatever default value you wish.
I did not try to add units in there.
usually when I am writing or modifying the configuration files, I used to
look at one of the example files provided. You can do the same if you
wish.
M.A.Meguid
UWO, Canada
Sebastian
For structural analysis, it could be very useful to take a look to the
configuration files of calsef (www.cimne.upc.es/calsef), the GiD+ module for
this kind of simulations.
-----Original Message-----
[mailto:owner-gid at gatxan.cimne.upc.es]On Behalf Of Mohamed Abdalla
Abdel-Meguid
Sent: Tuesday, August 22, 2000 6:24 PM
Subject: Re: [ GiDlist ] load vector
*.cnd file I
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
this line
meshing get
kN/m? It seem
to be the last one.
yes you can,
files, I used to
wish.
M.A.Meguid
UWO, Canada
Sebastian
