Can use a info list_entities of all lines, and then use a regexp to extract the desired information.
For example, can use this tcl procedure to get the list of lines with $higher higherentities
proc GetListLinesHigher { higher } {
set infolines [.central.s info list_entities lines 1:]
set ret “”
foreach {string num} [regexp -all -inline “Num: ([0-9]+) HigherEntity: $higher” $infolines] {
lappend ret $num
return $ret
set isolatedlines [GetListLinesHigher 0]
Sent: Monday, December 01, 2003 4:33 PM
Subject: Re: [GiDlist] lines with higher entities
but using this command will not give me a list of variable that contains the Id number of the lines, I don’t want to do this manually as you know.
in my code what i want is to find the ID of all the lines with (higherentity=0) and then find their coordinates.
I’m suing the following procedure but the problem is that GID doesn’t arrange the line Id in a sequence way.
proc CreateLinesList { } {
global Linelist
set Linelist {}
set Clist {}
set Dataeparator {}
set counter 0
set Entities [.central.s info list_entities status]
set index [lsearch $Entities “lines:”]
set NumberOfLiensIndex [expr $index + 1]
set NumberOfLiens [lindex $Entities $NumberOfLiensIndex]
WarnWinText $NumberOfLiens
for {set i_Dilines 1} {$i_Dilines = $NumberOfLiens} {incr i_Dilines} {
set Line [.central.s info list_entities Lines $i_Dilines]
set en_index [lsearch $Line “HigherEntity:”]
set en_index1 [expr $en_index + 1]
set enNumber [lindex $Line $en_index1]
WarnWinText $enNumber
if { $enNumber == 0 } {
set m_index [lsearch $Line “Points:”]
set m_index1 [expr $m_index + 1]
set Dip1 [lindex $Line $m_index1]
set m_index2 [expr $m_index + 2]
set Dip2 [lindex $Line $m_index2]
set Point [.central.s info list_entities Points $Dip1]
set mp_index [lsearch $Point “Coord:”]
set mp_index1 [expr $mp_index + 1]
set Dix_1 [lindex $Point $mp_index1]
set mp_index2 [expr $mp_index + 2]
set Diy_1 [lindex $Point $mp_index2]
set mp_index3 [expr $mp_index + 3]
set Diz_1 [lindex $Point $mp_index3]
set Point [.central.s info list_entities Points $Dip2]
set mp2_index [lsearch $Point “Coord:”]
set mp2_index1 [expr $mp2_index + 1]
set Dix_2 [lindex $Point $mp2_index1]
set mp2_index2 [expr $mp2_index + 2]
set Diy_2 [lindex $Point $mp2_index2]
set mp2_index3 [expr $mp2_index + 3]
set Diz_2 [lindex $Point $mp2_index3]
append Clist $Dataeparator $Dix_1 $Dataeparator $Diy_1 $Dataeparator $Diz_1 $Dataeparator $Dix_2
$Dataeparator $Diy_2 $Dataeparator $Diz_2
set counter [expr $counter + 1]
set Dataeparator " "
append Linelist $counter " " $Clist
Thanks a lot for your help
khaled
At 10:01 AM 12/1/2003, you wrote:
Can use some filter when selecting entities
Written this commands in the lower command line can list the isolated lines (higherentity=0)
escape escape escape utilities list line
filter:higher=0
1: escape
See also other filters in the selection window (menu Utilities-Graphical-Selection window…)
Sent: Wednesday, November 26, 2003 3:51 PM
Subject: [GiDlist] lines with higher entities
Hello Gid Team,
Is there a way to list all lines of 0 higher entities and then find these lines coordinates.
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031201/ae954f81/attachment.htm
