Apparently with the latest version I cannot plot stresses with line graphs
anymore. Do you know why? The option is available for border graphs
instead. It sounds very strange.
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100204/da7b5f39/attachment.htm
Alright, the option is still available in Window – View graphs. But in
this case Ctrl-a doesn’t work for joinig points, you have to do it by the
right-click menu.
Very strange bug,
NL.
2010/2/4 Nunzio Losacco nunzio.losacco at gmail.com
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100204/cec29518/attachment.htm
Sent: Thursday, February 04, 2010 1:42 PM
Subject: [GiDlist] Re: Line graphs in 9.2.7
Alright, the option is still available in Window – View graphs. But in this case Ctrl-a doesn’t work for joinig points, you have to do it by the right-click menu.
Very strange bug,
NL.
Apparently with the latest version I cannot plot stresses with line graphs anymore. Do you know why? The option is available for border graphs instead. It sounds very strange.
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100204/e90c9ac7/attachment.htm
The menu option was broken because we added a new Graph-Integrate option and we did some error on the neighbor menu.
Using the View graph window, Ctrl-a works, but the problem is that the focus is on this window instead the main window. if you click for example the caption of this window to set the focus you can see that Ctrl-a swaps the join - no join mode.
Very strange bug,
NL.
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100204/1dbe5305/attachment.htm
It seems that there is a bug in this version with the menu
View results-Graphs-Line graph
we will fix it.
but you can use: Window-View graphs…
using this window is more comfortable that using the other menu.
Sent: Thursday, February 04, 2010 1:38 PM
Subject: [GiDlist] Line graphs in 9.2.7
NL.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100204/afd377b2/attachment.htm
