[GiDlist] [GidList]problem
Hi, every body
How can i make the meshes of two geometries(in the same file)
independent?(different mesh and different density).
I try using layers for each geometry but it didnt work, when i mesh one
geometry, the other also change the same.
Roxana
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20070314/0fbbb602/attachment.htm
As I understand, do you have a model with two parts, and you want to obtain different mesh sizes, is not?
You can assign mesh sizes to geometrical entities (points, lines, surfaces or volumes):
Mesh-Unstructured-Assign sizes on…
Then the mesher try to obtain this sizes if they are possible.
Sent: Wednesday, March 14, 2007 9:21 AM
Subject: [GiDlist] [GidList]problem
Hi, every body
How can i make the meshes of two geometries(in the same file) independent?(different mesh and different density).
I try using layers for each geometry but it didnt work, when i mesh one geometry, the other also change the same.
Roxana
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20070314/103c8dc0/attachment.htm
