[GiDlist] GID version 7. for Sun Solaris
Dear Abedzade, could you send us the ouput of the command xdpyinfo?
xdpyinfo
abedzade wrote:
Hi, I need some advice to make GID work on my
computer. I have not
been
able to locate my question on FAQ page or the
current e-mail replies.
I downloaded the above version (7.0 Sun SOlaris)
and apparently
installed it successfully.
I can start running GID but if I pick any item from
geometry tool
bar, the screen will change to another color and I
will not be able to
see what have been on the screen before. However,
after I exit the command, the color goes back to
the original screen color
and I notice the command was executed.
Thanks;
Please find below the output of xdpyinfo command
laurel xdpyinfo
name of display: :0.0
version number: 11.0
vendor string: Sun Microsystems, Inc.
vendor release number: 6410
maximum request size: 262140 bytes
motion buffer size: 256
bitmap unit, bit order, padding: 32, MSBFirst, 32
image byte order: MSBFirst
number of supported pixmap formats: 3
depth 1, bits_per_pixel 1, scanline_pad 32
depth 8, bits_per_pixel 8, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 132
focus: window 0x5c00009, revert to PointerRoot
number of extensions: 29
AccessX
Adobe-DPS-Extension
DOUBLE-BUFFER
DPMS
DPSExtension
Extended-Visual-Information
FBPM
GLX
LBX
MIT-SCREEN-SAVER
MIT-SHM
MIT-SUNDRY-NONSTANDARD
Multi-Buffering
RECORD
SECURITY
SHAPE
SUN_ALLPLANES
SUN_DGA
SUN_OVL
SUN_SME
SYNC
SolarisIA
TOG-CUP
XC-APPGROUP
XC-MISC
XIE
XInputDeviceEvents
XInputExtension
XTEST
default screen number: 0
number of screens: 1
screen #0:
dimensions: 1280x1024 pixels (361x288 millimeters)
resolution: 90x90 dots per inch
depths (3): 1, 8, 24
root window id: 0x37
depth of root window: 8 planes
number of colormaps: minimum 1, maximum 5
default colormap: 0x34
default number of colormap cells: 256
preallocated pixels: black 1, white 0
options: backing-store YES, save-unders YES
largest cursor: 64x64
current input event mask: 0x78203f
KeyPressMask KeyReleaseMask ButtonPressMask
ButtonReleaseMask EnterWindowMask LeaveWindowMask
ButtonMotionMask SubstructureNotifyMask
SubstructureRedirectMask
FocusChangeMask PropertyChangeMask
number of visuals: 16
default visual id: 0x20
visual:
visual id: 0x20
class: PseudoColor
depth: 8 planes
available colormap entries: 256
red, green, blue masks: 0x0, 0x0, 0x0
significant bits in color specification: 8 bits
visual:
visual id: 0x21
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x22
class: StaticColor
depth: 8 planes
red, green, blue masks: 0x7, 0x38, 0xc0
visual:
visual id: 0x23
class: StaticGray
depth: 8 planes
visual:
visual id: 0x24
class: GrayScale
depth: 8 planes
visual:
visual id: 0x25
class: TrueColor
depth: 8 planes
available colormap entries: 8 per subfield
visual:
visual id: 0x26
class: DirectColor
depth: 8 planes
visual:
visual id: 0x27
class: StaticGray
depth: 8 planes
visual:
visual id: 0x2e
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x2f
class: PseudoColor
depth: 8 planes
available colormap entries: 255
visual:
visual id: 0x28
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff, 0xff00, 0xff0000
visual:
visual id: 0x29
class: TrueColor
depth: 24 planes
visual:
visual id: 0x2a
class: DirectColor
depth: 24 planes
visual:
visual id: 0x2b
class: DirectColor
depth: 24 planes
visual:
visual id: 0x2c
class: TrueColor
depth: 24 planes
visual:
visual id: 0x2d
class: TrueColor
depth: 24 planes
Dear Abedzade, GiD is using the first visual of depth 8. Now we are
trying to use first 32 then 24 and so on, when fixed we’ll release a
beta version with the correction.
best regards,
Jorge Suit
xdpyinfo
been
and apparently
geometry tool
will not be able to
Thanks;
laurel xdpyinfo
AccessX
Adobe-DPS-Extension
DOUBLE-BUFFER
DPMS
DPSExtension
FBPM
GLX
LBX
MIT-SCREEN-SAVER
MIT-SHM
Multi-Buffering
RECORD
SECURITY
SHAPE
SUN_ALLPLANES
SUN_DGA
SUN_OVL
SUN_SME
SYNC
SolarisIA
TOG-CUP
XC-APPGROUP
XC-MISC
XIE
XInputDeviceEvents
XInputExtension
XTEST
screen #0:
visual:
visual id: 0x20
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x21
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x22
class: StaticColor
depth: 8 planes
visual:
visual id: 0x23
class: StaticGray
depth: 8 planes
visual:
visual id: 0x24
class: GrayScale
depth: 8 planes
visual:
visual id: 0x25
class: TrueColor
depth: 8 planes
visual:
visual id: 0x26
class: DirectColor
depth: 8 planes
visual:
visual id: 0x27
class: StaticGray
depth: 8 planes
visual:
visual id: 0x2e
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x2f
class: PseudoColor
depth: 8 planes
visual:
visual id: 0x28
class: TrueColor
depth: 24 planes
visual:
visual id: 0x29
class: TrueColor
depth: 24 planes
visual:
visual id: 0x2a
class: DirectColor
depth: 24 planes
visual:
visual id: 0x2b
class: DirectColor
depth: 24 planes
visual:
visual id: 0x2c
class: TrueColor
depth: 24 planes
visual:
visual id: 0x2d
class: TrueColor
depth: 24 planes
