# \[GiDlist\] GiD 11 / right menu commands and batch commands no
**URL:** <https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51>\
**Category:** 2013 - 2005\
**Created:** [May 14, 2012, 2:48pm UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51 "2012-05-14T14:48:19Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![Janosch\_Stascheit](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/j/e5b9ba/32.png) [@Janosch\_Stascheit](https://forum.gidsimulation.com/u/Janosch_Stascheit)\
**Post date:** [May 14, 2012, 2:48pm UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/1 "2012-05-14T14:48:19Z")
</div>
I’m using batch files to generate my geometries. As I found out with GiD
11, the commands for selecting entities in the copy and move command do
not work anymore. Can anyone confirm this behaviour?
Janosch
**Author:** ![GiDTeam](https://forum.gidsimulation.com/user_avatar/forum.gidsimulation.com/gidteam/32/4_2.png) [@GiDTeam](https://forum.gidsimulation.com/u/GiDTeam)\
**Post date:** [May 15, 2012, 7:02am UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/2 "2012-05-15T07:02:12Z")
</div>
Hi Janosch,
Could you send me an example working on GiD 10 and not working on GiD 11
Thank you,
Adrià from GiD Team
El 14/05/2012 16:48, Janosch Stascheit escribió:
_Hi,_
_I’m using batch files to generate my geometries. As I found out with GiD_
_11, the commands for selecting entities in the copy and move command do_
_not work anymore. Can anyone confirm this behaviour?_
_Best regards_
_Janosch_
_GiDlist mailing list_
_[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
\_[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist\_](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist_)
**Post date:** [May 15, 2012, 7:17am UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/3 "2012-05-15T07:17:07Z")
</div>
please find attached the respective example. Try to open the GiD project
and then import the copy\_bug.bch file to perform the operation I am
usually using.
Janosch
Am Dienstag, den 15.05.2012, 09:02 +0200 schrieb Adria Melendo:
_Hi Janosch,_
_Could you send me an example working on GiD 10 and not working on GiD 11_
_Thank you,_
_Adrià from GiD Team_
_El 14/05/2012 16:48, Janosch Stascheit escribió:_
_Hi,_
_Best regards_
_Janosch_
Type: application/zip
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120515/843e82cc/attachment-0001.zip](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120515/843e82cc/attachment-0001.zip)
**Post date:** [May 15, 2012, 11:37am UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/4 "2012-05-15T11:37:07Z")
</div>
Hello Janosch,
This is a bug of GiD 11 (and last 10.1d betas) when selecting “all types”
and inverting a null selection
It will be fixed for next official and developer 11.x versions
Of do you want you can avoid the problem of these version for example
changing the process command
Utilities Copy AllTypes Translation 0,0,0 0,0,1 InvertSelection mescape
by
Utilities Copy AllTypes Translation 0,0,0 0,0,1 points InvertSelection
mescape
Thanks for your bug report
From: “Janosch Stascheit” [janosch.stascheit at rub.de](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Sent: Tuesday, May 15, 2012 9:17 AM
Subject: Re: [GiDlist] GiD 11 / right menu commands and batch commands not
working anymore
_Hi,_
_please find attached the respective example. Try to open the GiD project_
_and then import the copy\_bug.bch file to perform the operation I am_
_usually using._
_Best regards_
_Janosch_
_Am Dienstag, den 15.05.2012, 09:02 +0200 schrieb Adria Melendo:_
_Hi Janosch,_
_Thank you,_
_Hi,_
_I’m using batch files to generate my geometries. As I found out with_
_GiD_
_Best regards_
_Janosch_
## _GiDlist mailing list_ _[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_ \_[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist\_](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist_) \
**Author:** ![Farzam\_Arash](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/f/c2a13f/32.png) [@Farzam\_Arash](https://forum.gidsimulation.com/u/Farzam_Arash)\
**Post date:** [May 22, 2012, 8:01pm UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/5 "2012-05-22T20:01:49Z")
</div>
I have two different types of elements (hexahedra and quadrilateral).
I know there is a simple command to write the total number of
elements. Is there also a xommand to write the total number of
hexahedra elements? or total number of quadrilateral elements?
Best Regards,
Arash
**Post date:** [May 23, 2012, 8:58am UTC](https://forum.gidsimulation.com/t/gidlist-gid-11-right-menu-commands-and-batch-commands-no/51/6 "2012-05-23T08:58:28Z")
</div>
I assume that do you want to write this number in the calculation file from
the .bas template
\*nelem write the total number of elements,
but as is explained in Help-GiD customization - Template files… it
could have an extra argument
to specify the kind of elements: Point, Linear, Triangle, Quadrilateral,
Tetrahedra, Hexahedra, Prism, Pyramid, Sphere, Circle
e.g.
\*nelem(Hexahedra)
\*nelem(Quadrilateral)
At Tcl scripting language there also exists GiD extra commands to ask for
this information
e.g.
GiD\_Info Mesh NumElements Hexahedra
From: “Farzam, Arash” [farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Sent: Tuesday, May 22, 2012 10:01 PM
Subject: [GiDlist] Number of Certain Element type
_Hello,_
_I have two different types of elements (hexahedra and quadrilateral)._
_I know there is a simple command to write the total number of_
_elements. Is there also a xommand to write the total number of_
_hexahedra elements? or total number of quadrilateral elements?_
_Best Regards,_
_Arash_
