[ GiDlist ] (*.falvia.res) format..?
I have been trying to learn using GID as a post processing
environment. I am interested in the `new’ file format
(*.falvia.res) only. So as a start, I wanted to try out the
example available in the online manual:
1- Create the mesh file (.falvia.msh)
2- Create the result file (
.falvia.res)
3- Load up the mesh file in the ‘Preprocess’ mode
using the (Files – Import – Mesh Read).
4- Move to the ‘Postprocess’ mode.
5- Try to load up the result file using (Open):::=
GiD complains about reaching the “EOF” in the
second line…!?
6- Assuming there is a problem in reading the blank lines,
I changed the blank lines to comments lines:::=
Gid complains:
(Node out of range: in this line: 9 - Reading Results.)
Any comment is appreciated…
Many thanks
Rajab
P.S.
  • Both files have been stored under one directory with
    the same project name.
    ** While I was using (copy and past) to create the files,
    I noticed a ‘typing mistake’ in one of the keywords
    (i.e. Ntural instead of Natural). Correcting this has not
    changed the above at all..
    *** I am using (Gid 6.1.2 Academic version) on an SGI workstation,
    and I have not experienced any problem with the examples
    were included in the download files, or any other file
    I have created (i.e. different type of meshes only without
    any associated solution).
*.flavia.msh
.flavia.res - the extension ‘.flavia.’ is only used
inside a '
.gid’ project to ‘automatically’ read the results
when passing from pre- to post-.
The new postprocess format can be read with GiD version
6.1.4b or higher, available at:
http://gid.cimne.upc.es/download
under ‘Download GiD beta versions’, or at:
ftp://gid.cimne.upc.es/pub/gid_adds/
Hope it helps,
p.s.: Thanks for the ‘typing mistake’, now is corrected.
1- Create the mesh file (*.falvia.msh)
2- Create the result file (*.falvia.res)
second line…!?
Gid complains:
Many thanks
Rajab
P.S.
* Both files have been stored under one directory with
If you want to load files *.flavia.msh and
*.flavia.res in the postprocessor, the easiest way
is:
1- open GiD
2- go to postprocess
3- open either the *.flavia.msh or the *.flavia.res, both
files will be load.
Remember that to use the new Post format it is necessary to
download a recent beta version.
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Rajab Said
Enviado el: viernes, 28 de septiembre de 2001 12:36
Asunto: [ GiDlist ] (*.falvia.res) format..?
.falvia.res)
second line…!?
Gid complains:
Many thanks
Rajab
P.S.
