[GiDlist] Export of entities from *.mat file
Dear All
I am using an interface template, which is similar to NASTRAN. I want to use a special format for the export of material and property data (large format w/ 2 rows). The first entry in the 2nd row has to be a matprop(xx) entry, which doesn’t work properly.
I checked the version 7 (beta-2) for this output issue. It seems to be an error, because the output for this matprop(xx) works well after matnum(yy), but not as the first request!
Do you have similar experience? What can be a workaround?
Ruediger
*matprop(xx) must be inside a *loop materials.
If it is not able to solve it, send us your problem type and a small sample.
The GiD Team.
Sent: Monday, June 24, 2002 2:51 PM
Subject: [GiDlist] Export of entities from *.mat file
Dear All
Ruediger
