# \[GiDlist\] Error reading resultfile: Couldn&#39;t find &#39;e
**URL:** <https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268>\
**Category:** 2013 - 2005\
**Created:** [February 21, 2013, 9:54am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268 "2013-02-21T09:54:20Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![Bronsert\_Jeffrey](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/b/ecc23a/32.png) [@Bronsert\_Jeffrey](https://forum.gidsimulation.com/u/Bronsert_Jeffrey)\
**Post date:** [February 21, 2013, 9:54am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/1 "2013-02-21T09:54:20Z")
</div>
Dear GID users,
I’m using GID 9.06 on a 64bit Windows platform with 8Gb RAM. My problem is that GID gives an error message, while reading the result file (2Gb). Has GID a limit for the size of a result file? Is there a way to read the whole file or do I need to divide it to make the file smaller.
Jeff
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/8d1689a8/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/8d1689a8/attachment.htm)
**Post date:** [February 21, 2013, 11:48am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/2 "2013-02-21T11:48:01Z")
</div>
Are you sure that the results file is not truncated? (maybe the solver has not finished this file)
Are you using a x64 version of GiD? (because you can also use a x32 verision in your x64 platfrom)
If you are using a x32 version then a process has a limit of 2GB (it’s not a GiD limit, it’s a system limit)
Whith GiD 11 (and latest 10 developer versions) exists a new option in Utilities-Preferences-Postproces, named “Use result cache”,
activating this option you specify the maximum amount of memory that GiD could use for the results, and it automatically handle load/unload from memory unused results to allow read very big files (e.g. 100GB)
Sent: Thursday, February 21, 2013 10:54 AM
Subject: [GiDlist] Error reading resultfile: Couldn’t find ‘end values’, in line 12568610
Dear GID users,
## Jeff \
[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/a8aaf783/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/a8aaf783/attachment.htm)
**Post date:** [February 21, 2013, 4:49pm UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/3 "2013-02-21T16:49:44Z")
</div>
Dear Enrique,
thank you for your answer. I looked at the file and it is not truncated. I also read the resultfile on another machine with only 4 Gb RAM and it appeared the same error “Error reading resultfile: Couldn’t find ‘end values’, in line 12568610”. Both machines use a GID 9.06 64 bit version.
On the line 12568610 is “end values” written.
I also tried to read another big resultfile (2.5 Gb) and it appeared the same error on a different line number “Error reading resultfile: Couldn’t find ‘end values’, in line 77294015”. In this line of the resultfile there is also an “end values” written.
Smaller resultfiles are read by GID. All resultfiles are written by the same subroutine.
Can GID read only a specific amount of results?
Jeff
Von: [gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) [mailto:[gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)] Im Auftrag von Enrique Escolano
Gesendet: Donnerstag, 21. Februar 2013 12:48
An: [gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Betreff: Re: [GiDlist] Error reading resultfile: Couldn’t find ‘end values’, in line 12568610
From: Bronsert, Jeffreymailto:[jeffrey.bronsert at bam.de](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
To: [gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)mailto:[gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Dear GID users,
Jeff
[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)mailto:[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/1ec81492/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/1ec81492/attachment-0001.htm)
**Post date:** [February 21, 2013, 5:59pm UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/4 "2013-02-21T17:59:31Z")
</div>
In theory there is not any limit on GiD, but the version 9 was released several years ago
Try with a modern 11.x version (can try it with a free one month password) . In this version can also activate the related ‘results cache’
Or at least, try the last 9.3.1d win x64 developer (last 9 version) that can use the same password that your current 9.0.6 version.
Sent: Thursday, February 21, 2013 5:49 PM
Subject: Re: [GiDlist] Error reading resultfile: Couldn’t find ‘end values’,in line 12568610
Dear Enrique,
Jeff
Dear GID users,
## Jeff \
## GiDlist mailing list [GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) [http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) \
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/4fd4f496/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130221/4fd4f496/attachment.htm)
**Post date:** [February 22, 2013, 10:57am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/5 "2013-02-22T10:57:20Z")
</div>
Dear Enrique,
I tried the developer version (9.3.1d.win x64), but the same problem appeared. It seems to me that the 9 version can’t deal with resultfiles greater than 2 Gb. Is there any possibility to solve this problem for the 9 version?
Jeff
Gesendet: Donnerstag, 21. Februar 2013 19:00
Dear Enrique,
Jeff
Von: [gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)mailto:[gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) [mailto:[gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)] Im Auftrag von Enrique Escolano
An: [gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)mailto:[gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Dear GID users,
Jeff
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/f10daa70/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/f10daa70/attachment-0001.htm)
**Post date:** [February 22, 2013, 11:47am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/6 "2013-02-22T11:47:43Z")
</div>
Try also with GiD 11 and a temporary free password (to verify at least that it’s not a problem of the result file)
(try without ant with activating the “results cache”)
Sent: Friday, February 22, 2013 11:57 AM
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear GID users,
## Jeff \
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/b0a04f02/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/b0a04f02/attachment.htm)
**Post date:** [February 22, 2013, 4:19pm UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/7 "2013-02-22T16:19:34Z")
</div>
Dear Enrique,
Gid 11 read the result files with and without the “result cache” option. For the “result cache” option I tried the 256 Mb, 512 Mb and 1024 Mb option. No problem occurred with these options.
Jeff
Gesendet: Freitag, 22. Februar 2013 12:48
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear GID users,
Jeff
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/1bf8215c/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/1bf8215c/attachment-0001.htm)
**Post date:** [February 22, 2013, 4:46pm UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/8 "2013-02-22T16:46:27Z")
</div>
I think that the problem was related to the version of the zlib compression library used in the version 9 of Windows, with files 2Gb
Maybe you could be able to read a file bigger of 2GB with GiD 9.x Windows x64 using ASCII results format (binary format use compression).
Off course in ASCII format the same file will be bigger, and slower to be read.
Sent: Friday, February 22, 2013 5:19 PM
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear GID users,
## Jeff \
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/493b9c63/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130222/493b9c63/attachment-0001.htm)
**Post date:** [February 25, 2013, 9:13am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/9 "2013-02-25T09:13:32Z")
</div>
Dear Enrique,
the result file is already written in ASCII format. I use a subroutine to write the result file which always writes the results in ASCII format following the description in the reference manual.
Jeff
Gesendet: Freitag, 22. Februar 2013 17:46
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear GID users,
Jeff
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130225/9b9de86e/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130225/9b9de86e/attachment-0001.htm)
**Post date:** [February 25, 2013, 10:59am UTC](https://forum.gidsimulation.com/t/gidlist-error-reading-resultfile-couldn-39-t-find-39-e/268/10 "2013-02-25T10:59:13Z")
</div>
Then seems that with the version 9 is not possible to postprocess this big results files.
The only way is to write smaller files (avoiding some write some result, or less time steps) or use a modern GiD version.
Sent: Monday, February 25, 2013 10:13 AM
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear Enrique,
Jeff
Dear GID users,
## Jeff \
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130225/f1e8e353/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130225/f1e8e353/attachment-0001.htm)
