[GiDlist] crash while visualizing my result
Hello GID team,
Attached is my *.res file that contains both “Scalar OnNodes” and “Vector
OnNodes”.
GID 7.4 crashes when I switch between the two type of data and it gives the
following message. could you please let me know what is wrong.
Thank you
bad option “E” in “cur_vector_factor”: must be { arewein, get {
results_options, all_volumesets, all_surfacesets, all_cutsets,
cur_volumesets, cur_surfacesets, cur_cutsets, all_display_styles,
cur_display_style, all_analisis, all_setps, cur_analisis, cur_step,
all_results_views, cur_results_view, cur_results_list, results_list,
cur_result, cur_components_list, components_list, cur_component,
main_geom_state, main_geom_factor, main_geom_all_deform,
main_geom_cur_deform, show_geom_state, show_geom_factor,
show_geom_all_deform, show_geom_cur_deform, show_geom_cur_analisis,
show_geom_cur_step}}
while executing
".gid.central.s info post get cur_vector_factor $cur_res_view $cur_res
$cur_anal $cur_step "
(“Display_Vectors” arm line 2)
invoked from within
"switch $cur_res_view {
“Iso_Surfaces” {
set values [.gid.central.s info post get iso_cur_result_values]
set restcommand “$pp exact $cur_res…”
(procedure “AddAnalysisStepsToMenu” line 23)
invoked from within
“AddAnalysisStepsToMenu .mm1.button4.3”
(menu preprocess)
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/f0ec0779/attachment.htm
Have you tried the latest beta? ftp://www.gidhome.com/pub/gid_adds/Windows/
ftp://www.gidhome.com/pub/gid_adds/Windows/GiD7.4.6b-win.exe
GiD7.4.6b-win.exe
Can you please provide me with the required password?
here is my machine information.
Machine bessel01
Operating system Windows
ID number 42f8ab7800000069
Mail kobeidat at yahoo.com
Connected from: 152.160.4.10
the same password used for the 7.4 should work for this beta (generally the
password file is located at \program files\gid\gid7.4\scripts\TemporalVariables
just copy this to the scripts dorectory of the gid7.4.6b)
the last password you asked for was:
Code for: windows bessel01 - 42f8ab7800000069
bq9e-huh1-p851-9sx8-sgpt-nxgr-1p
whish is still valid
best regards
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Khaled Obeidat
Enviado el: viernes, 13 de febrero de 2004 16:55
Asunto: RE: [GiDlist] crash while visualizing my result
Machine bessel01
GiD7.4.6b-win.exe
Enviado el: jueves, 12 de febrero de 2004 16:16
Asunto: [GiDlist] crash while visualizing my result
Hello GID team,
OnNodes”.
Thank you
results_options, all_volumesets, all_surfacesets, all_cutsets, cur_volumesets,
cur_surfacesets, cur_cutsets, all_display_styles, cur_display_style,
all_analisis, all_setps, cur_analisis, cur_step, all_results_views,
cur_results_view, cur_results_list, results_list, cur_result,
cur_components_list, components_list, cur_component, main_geom_state,
main_geom_factor, main_geom_all_deform, main_geom_cur_deform, show_geom_state,
show_geom_factor, show_geom_all_deform, show_geom_cur_deform,
show_geom_cur_analisis, show_geom_cur_step}}
while executing
invoked from within
“Iso_Surfaces” {
invoked from within
(menu preprocess)
Khaled Obeidat
Research Engineer
www.emagtechnologies.com http://www.emagtechnologies.com/
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040213/6bac11b1/attachment.htm
I have tried the gid7.4.6b and I’m getting the same error message.
the password file is located at \program
files\gid\gid7.4\scripts\TemporalVariables just copy this to the scripts
best regards
Machine bessel01
ftp://www.gidhome.com/pub/gid_adds/Windows/GiD7.4.6b-win.exea href="ftp://www.gidhome.com/pub/gid_adds/Windows/ftp://www.gidhome.com/pub/gid_adds/Windows/GiD7.4.6b-win.exe"ftp://www.gidhome.com/pub/gid_adds/Windows/ftp://www.gidhome.com/pub/gid_adds/Windows/GiD7.4.6b-win.exe/aGiD7.4.6b-win.exe
Hello GID team,
Attached is my *.res file that contains both “Scalar OnNodes” and "Vector
OnNodes".
the following message. could you please let me know what is wrong.
Thank you
while executing
invoked from within
“Iso_Surfaces” {
invoked from within
(menu preprocess)
Khaled Obeidat
Research Engineer
Khaled Obeidat
Research Engineer
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040216/cad0d99f/attachment.htm
Is it possible to access and output, with a *.bas file, geometric entity
data such as points, lines, surfaces and volumes using commands similar
to those for nodes and elements?
Randy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/9de2669a/attachment.htm
MessageNot, from the bas file only can directly access to mesh entities.
To output geometric entities must use tcl, a powerful script language
Can ask GiD about the geometric entities with .central.s info procedures
Note: your bas file can invoke a tcl procedure with the *tcl command.
Sent: Thursday, February 12, 2004 5:10 PM
Subject: [GiDlist] Geometric Entities
Is it possible to access and output, with a *.bas file, geometric entity data such as points, lines, surfaces and volumes using commands similar to those for nodes and elements?
Randy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/2bf7ed58/attachment.htm
