hi,
Just assign the element size you want to the end points
of the line.
From: Pablo Perez del Castillo pablopdc at terra.es
Subject: [GiDlist] concentrate elements
Date: Tue, 05 Nov 2002 23:07:10 -0600
Hi;
It is possible to concentrate elements at the begining and at the end of
the
same line to mesh a surface?
Advanced thanks
Pablo
MSN. Más Útil Cada Día http://www.msn.es/intmap/
It is also possible to assign a structured number of divisions to a line
Meshing-Structured-Lines
(and select the number of elements for the selected lines)
This elements can be concentrated at the start, the end, boths,.. assigning
a weight to the start and end
with:
Meshing-Structured-Concentrate Elements
(and select the structured lines and the start and end weights)
From: “Miguel A. de Riera Pasenau” miguel_pasenau at hotmail.com
Sent: Wednesday, November 06, 2002 12:35 AM
Subject: Re: [GiDlist] concentrate elements
hi,
of the line.
Hi;
the
Advanced thanks
Pablo
_MSN. Más Útil Cada Día http://www.msn.es/intmap/_
Hi;
My question, if it is possible structured concentrate elements in version 6,
like in version 7, where you can control the mesh at the beginning and at the
end.
Pablo
“Miguel A. de Riera Pasenau” escribió:
hi,
of the line.
Hi;
the
Advanced thanks
Pablo
In GiD version 6 only is possible to concentrate structured elements at
start or
at end, but not at both, this is a new feature of GiD 7.
Sent: Wednesday, November 06, 2002 6:41 PM
Hi;
6,
the
end.
Pablo
hi,
of the line.
Hi;
of
the
Advanced thanks
Pablo
When meshing a perfectly symmetric geometry, GID does not produce a
mesh with perfectly symmetric node locations no matter how much I
alter the meshing parameters. To produce a symmetric mesh, I instead mesh
one quarter of the geometry and copy/mirror the elements.
However, since I need double nodes in my geometry, I must check the
“duplicate entities” box in the copy window or else my double nodes will
be collapsed to single nodes. As a consequence, I am left with double
nodes along the mirroring boundaries which must then be deleted.
Is there a simpler way to make GID produce a symmetric mesh for symmetric
geometries?
thanks,
Jeramy Ashlock
Not exist any method to force GiD to generate a symmetric
mesh for symmetric geometries, must copy/mirror directly the elements.
From: “Jeramy Ashlock” ashlock at bechtel.colorado.edu
Sent: Wednesday, November 06, 2002 1:33 AM
Subject: [GiDlist] Symmetry
geometries?
thanks,
Jeramy Ashlock
