[GiDlist] Color fill in postprocess using Natural Coordinate
Dear all:
While I use Color Fill option to view results for a 8-node quadrilateral by
Natural coordinate of Gauss point given I just saw color at each Gauss
points not color fill as usual. This problem occurs as I use 4x4 Gauss
points but does not as I use 2x2 Gauss points.
Can you help me to fix this trouble to have true color fill over whole
elements?
I attach here the project files, including project.flavia.res created by
myself.
Thank you in advance and I am looking forward to hearing from you.
Best,
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091205/319ec54d/attachment.htm
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091205/319ec54d/attachment.zip
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091205/319ec54d/attachment.jpg
Dear all:
While I use Color Fill option to view stress results for a 8-node
quadrilateral by Natural coordinate of Gauss point given I just saw color at
each Gauss points not color fill as usual. This problem occurs as I use 4x4
Gauss points but does not as I use 2x2 Gauss points.
elements?
myself.
Best,
Thanh
P/S: I sent this email before but there is no answer. Please help me
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091210/b03c15ed/attachment.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091210/b03c15ed/attachment.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091210/b03c15ed/attachment.zip
hi,
i imported an .stl file and used the function
Geometry - Create - Surface mesh.
after that, i got the message:
Error: element 23434 has two or more adyacent elements
at the same edge - elem 23988 and elem 23709. Cannot continue.
so my question are
-how can a fix the problem?
-is there a way to find the elements and delete them?
-or can i change somethings in options of the programm to get it fixed?
thx
martin
hi,
i solved my problem with creating the surface. i just had to simplify my mesh.
but now i got the next problem with creating an volume!
i got these errors:
line number 1 is 1 times into volume generation
line number 2 is 1 times into volume generation
line number 3 is 1 times into volume generation
line number 124 is 1 times into volume generation
line number 123 is 1 times into volume generation
line number 122 is 1 times into volume generation
line number 130 is 1 times into volume generation
surface 1 is over 20 surfaces
surface 2 is over 8 surfaces
surface 3 is over 2 surfaces
surface 5 is over 2 surfaces
surface 9 is over 2 surfaces
surface 10 is over 2 surfaces
surface 13 is over 2 surfaces
surface 15 is over 2 surfaces
surface 19 is over 2 surfaces
surface 20 is over 2 surfaces
surface 22 is over 2 surfaces
surface 26 is over 2 surfaces
surface 27 is over 2 surfaces
surface 28 is over 2 surfaces
Problem with lines: 1 2 3 124 123 122 130
Problem with surfaces: 1 2 3 5 9 10 13 15 19 20 22 26 27 28
is there a described way to fix these problems?
thx for helping
martin
An embedded message was scrubbed…
From: MArtin Koske martin.koske at medien.uni-weimar.de
Subject: generating surface mesh from stl
Date: Tue, 08 Dec 2009 14:26:13 +0100
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091208/1baf6c99/attachment.eml
Dear Martin,
Maybe a Geometry-Edit-Collapse-Model could help you but it seems that the
problem comes from stl file that you have used or in some step from mesh to
surfmesh process.
Also surfmesh creation it’s a bit tricky, you can access to all options by
“right buttons” menu (to add “right buttons”, do right click on command
line-Configure toolbar) Geometry-Create-SurfMesh, try with “ImproveMesh
no”.
Anyway, if you could send me (my email is amelendo at cimne.upc.edu) your stl
and the GiD file where the volume creation errors appear I could tell you
the right answer.
Adrià
AVISO IMPORTANTE
Los datos de carácter personal facilitados están registrados en un fichero
con la finalidad de facilitar la gestión de las comunicaciones de CIMNE.
Puede ejercitar los derechos de acceso, rectificación, cancelación y
oposición mediante petición dirigiéndose a nuestras oficinas en Ed. C1
Campus Norte UPC. Gran Capitán s/n Barcelona
AVIS IMPORTANT
Les dades de caràcter personal facilitades seran registrades en un fitxer
amb la finalitat de facilitar les gestions de les comunicacions de CIMNE.
Pot exercir els drets d’accés, rectificació i cancel·lació, per escrit a les
nostres oficines en Ed. C1 Campus Nord UPC. Gran Capità s/n Barcelona.
IMPORTANT NOTICE
All personal data contained on this mail will be processed confidentially
and registered in a file property of CIMNE., in order to manage corporate
communications. You may exercise the rights of access, rectification,
erasure and object by letter sent to Ed. C1 Campus Norte UPC. Gran Capitán
s/n Barcelona.
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de MArtin Koske
Enviado el: martes, 08 de diciembre de 2009 16:29
Asunto: [GiDlist] generating surface mesh from stl new
hi,
mesh.
i got these errors:
thx for helping
martin
