[GiDlist] Book option over Interval Data
Greetings GiD Experts
I am new using GiD and I am trying to explore the possibility of using
GiD as Pre-Post for the F.E. solver GEFDyn developped at the MSSMat
Laboratory at Ecole Centrale Paris. I have begun by writting the
*.bas files in order to obtain the text files needed to use GEFDyn. By
exploring the options I tryed to use the BOOK option over the Interval
Data, in screen it goes well, I’m able to assign different intervals
according to my needs. But then a problem appears when I try to use
the *loop over Invervals, an error appears because there are different
curves with the same number, and it is so because each book re-starts
a new number sequence for the intervals data. Then, the question is:
is there an option, that obviously I am not including, to precise over
which book the loop should be done on the *.bas file?. or It is not
possible and I have to use a script TCL?
For information I am using the 1 month license for V 9.0.4
Cristian NIETO
PhD Student
Laboratoire de Mécanique de Sols, Structures et Materiaux - LMSSMat
Research Engineer
Coyne et Bellier. Bureau d’ingénieurs Conseils
Paris - France
