[GiDlist] .bas file problems
Win98 GiD 6.3.0b
Dear GiD team & users
I’m having some problems with unexpected behaviour of *if *else *elseif
etc
can you have a look at the attached code and tell me why the output is not
as expected
rgbtest.bas = sample code
rgb.txt = output of .bas code
expected.txt what I expect the output to be ( done in mathcad)
expected.txt RGBtest.bas rgb.txt
Mark
+44 (0)1480302100
http://www.linx.co.uk/
person.
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020524/cae5d47d/attachment.txt
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020524/cae5d47d/attachment.obj
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020524/cae5d47d/attachment-0001.txt
This is bug of GiD parsing the condition if(z=e1)
the variable e1 is evaluated incorrectly as a exponential number 0e1, not as the variable named e1,
and the result is only true if z=0
This bug is corrected for the next GiD version.
You can avoid this bug if not use names as e"number" (e1, e206, etc) for the variables.
Thanks for your report.
Sent: Friday, May 24, 2002 4:38 PM
Subject: [GiDlist] .bas file problems
Win98 GiD 6.3.0b
etc
as expected
Mark
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020527/b17c2d2b/attachment.htm
