[GiDlist] bas file problem
Found a solution, my mistake was misusing *ElemsMat
Solved the problem by changing my material file and the following in my bas
file
*loop materials
*set var MaterialNum(int)=Operation(MatProp(Number,int))
*loop elems
*ElemsNum 1 29650 *MaterialNum *ElemsConec
*end elems
*end materials
mark
-----Original Message-----
Sent: 23 July 2002 12:44
To: Gidlist (E-mail)
Subject: [GiDlist] bas file problem
win98 GiD6.3.0b
Dear GiD team,
I am having a problem writing out a mesh data file in my required format.
the following few lines from my .bas file are giving me problems:
*loop elems
*ElemsNum 1 29650 *ElemsMat *ElemsConec
*end elems
no mater what material I asign to my volume before meshing (linear tets),
the output file always shows the value 1 as the elements material.
If I do a write mesh then the output file shows the correct material number?
Whats going on?
Mark
+44 (0)1480302100
http://www.linx.co.uk/
person.
+44 (0)1480302100
person.
Hi troops
Im having trouble importing files in dxf format from Qcad to Gid. This
problem seems to just have appeared since i upgraded to V7.0. Sometimes it
works and sometimes Gid just shuts down. I didnt experience this with 6.03?
Anybody else have this problem or any advice
Thanks a lot
Mike
can you send us a little example where this happens, so we can
check it out?
are you running in windows/linux/…?
Mike Monti wrote:
Hi troops
Thanks a lot
Mike
Hola Miguel
y beunos dias.
Im running gid on a linux machine using turbolinux, I dont have windows or
dos on this machine.
Attached is a dxf file where this does happen printing.dxf and one where it
works fine, paper.dxf. I cant seem to make the connection between what will
work and what wont work. I suspect Qcqd dxf and Gid dsf are different
versions of dxf.
Muchas gracias
Mike
0
SECTION
2
HEADER
9
$LIMMIN
10
0.000000
20
0.000000
9
$LIMMAX
10
155.563380
20
253.154930
9
$EXTMIN
10
0.000000
20
0.000000
9
$EXTMAX
10
155.563380
20
253.154930
9
$ANGBASE
50
0.000000
9
$ANGDIR
70
0
9
$INSUNITS
70
4
9
$DIMALT
70
4
9
$DIMLUNIT
70
2
9
$DIMASZ
40
3.000000
9
$DIMTXT
40
5.000000
9
$DIMRND
40
0.010000
9
$DIMEXE
40
2.000000
9
$DIMEXO
40
2.000000
9
$DIMAUNIT
70
0
9
$DIMADEC
70
2
9
$GRIDUNIT
10
0.001000
20
0.001000
9
$PLIMMIN
10
0.000000
20
0.000000
9
$PLIMMAX
10
210.000000
20
297.000000
9
$PSVPSCALE
40
1.000000
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
LTYPE
70
1
0
LTYPE
2
CONTINUOUS
70
64
3
Ausgez
72
65
73
0
40
0.000000
0
ENDTAB
0
TABLE
2
LAYER
70
1
0
LAYER
2
default
70
64
62
0
6
CONTINUOUS
0
ENDTAB
0
ENDSEC
0
SECTION
2
BLOCKS
0
ENDSEC
0
SECTION
2
ENTITIES
0
LINE
8
default
6
CONTINUOUS
10
35.563380
20
253.154930
11
35.563380
21
193.154930
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
35.563380
20
193.154930
11
155.563380
21
193.154930
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
155.563380
20
193.154930
11
155.563380
21
253.154930
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
155.563380
20
253.154930
11
35.563380
21
253.154930
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
130.790806
20
212.939394
11
95.790806
21
212.939394
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
45.563380
20
223.154930
40
4.250000
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
63.563380
20
223.154930
40
4.250000
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
45.563380
20
244.154930
40
5.000000
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
45.563380
20
202.154930
40
5.000000
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
145.563380
20
244.154930
40
5.000000
39
0
62
0
0
CIRCLE
8
default
6
CONTINUOUS
10
145.563380
20
202.154930
40
5.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
95.790806
20
232.939394
11
130.790806
21
232.939394
39
0
62
0
0
ARC
8
default
6
CONTINUOUS
10
95.790806
20
222.939394
40
10.000000
50
90.000000
51
270.000000
39
0
62
0
0
ARC
8
default
6
CONTINUOUS
10
130.790806
20
222.939394
40
10.000000
50
270.000000
51
90.000000
39
0
62
0
0
ENDSEC
0
EOF
0
SECTION
2
HEADER
9
$LIMMIN
10
0.000000
20
0.000000
9
$LIMMAX
10
140.000000
20
260.000000
9
$EXTMIN
10
0.000000
20
0.000000
9
$EXTMAX
10
140.000000
20
260.000000
9
$ANGBASE
50
0.000000
9
$ANGDIR
70
0
9
$INSUNITS
70
4
9
$DIMALT
70
4
9
$DIMLUNIT
70
2
9
$DIMASZ
40
3.000000
9
$DIMTXT
40
5.000000
9
$DIMRND
40
0.010000
9
$DIMEXE
40
2.000000
9
$DIMEXO
40
2.000000
9
$DIMAUNIT
70
0
9
$DIMADEC
70
2
9
$GRIDUNIT
10
0.001000
20
0.001000
9
$PLIMMIN
10
0.000000
20
0.000000
9
$PLIMMAX
10
210.000000
20
297.000000
9
$PSVPSCALE
40
1.000000
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
LTYPE
70
1
0
LTYPE
2
CONTINUOUS
70
64
3
Ausgez
72
65
73
0
40
0.000000
0
ENDTAB
0
TABLE
2
LAYER
70
1
0
LAYER
2
default
70
64
62
0
6
CONTINUOUS
0
ENDTAB
0
ENDSEC
0
SECTION
2
BLOCKS
0
ENDSEC
0
SECTION
2
ENTITIES
0
LINE
8
default
6
CONTINUOUS
10
60.000000
20
260.000000
11
60.000000
21
10.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
60.000000
20
10.000000
11
65.000000
21
10.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
65.000000
20
10.000000
11
65.000000
21
260.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
65.000000
20
260.000000
11
60.000000
21
260.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
100.000000
20
260.000000
11
100.000000
21
10.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
100.000000
20
10.000000
11
140.000000
21
10.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
140.000000
20
10.000000
11
140.000000
21
260.000000
39
0
62
0
0
LINE
8
default
6
CONTINUOUS
10
140.000000
20
260.000000
11
100.000000
21
260.000000
39
0
62
0
0
ENDSEC
0
EOF
My GiD version 7 can read correctly your printing.dxf. What problem
appears to you?
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Mike Monti
Enviado el: miércoles, 31 de julio de 2002 22:29
Asunto: Re: [GiDlist] DXF files
Hola Miguel
y beunos dias.
versions of dxf.
Muchas gracias
Mike
