You were exactly right Miguel. My displacement name was different.
I had put it different since I got an error regarding Gauss Points when I
used the same name for all the time steps.
It turned out that the name needed to be 15 characters, just like in the
example
you told me about.
Now it works fine!
Thank you!
/Jonas
From: “Miguel A. de Riera Pasenau” miguel at cimne.upc.es
Subject: Re: [GiDlist] Animations of deformations in a time step analysis
Date: Mon, 26 Nov 2001 10:29:54 +0100
have you checked if the result’s name is the same all the time steps?
_in ftp://gid.cimne.upc.es/pub/gid/Examples_
you can find the example: ‘mensu.dat’ and ‘mensu.res’ with
four steps. Each one of these steps has the result ‘DESPLACEMENTS’
which can be used to deform the mesh. The name of this result, its type,
its location, remain the same for all the steps, and only the step value
varies.
When the deformation is animated, GiD shows the ‘original’ state and
the four deformed ones with the same factor.
if your example still doesn’t work, can you send us a short version
of the files, so we can take a lok into them?
Jonas Forssell wrote:
I Use GID 6.1.2a to animate deformations from a crash simulation code
which
uses
explicit time step solutions.
Each time step has a slightly different deformation for the mesh. These
are
all possible to view in the traditional manner (using View Results -
Default time step / Deformation). The trouble begins when I want to
animate
the steps.
The animation just shows the mesh in an undeformed state
for all time steps EXCEPT the one I have previously selected in the
Window -
Mesh Deformation panel.
How can I make it show all of the deformations during the animation?
All the best
/Jonas Forssell, Gothenburg, Sweden
Get your FREE download of MSN Explorer at
_http://explorer.msn.com/intl.asp_
Miguel A. de Riera Pasenau miguel at cimne.upc.es
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
