[GiDlist] A bug about polyline
HI:
I find a bug in Gid.When I have created a PolyLine and extrude it to a
surface.Then if you will render it you will find a erro surface.I attched an
example.
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020912/717a48d3/attachment.obj
The compressed rar file is corrupted,
please send us another copy of the .geo file.
Sent: Thursday, September 12, 2002 1:22 PM
Subject: [GiDlist] A bug about polyline
HI:
an
example.
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Dear GiD members,
I have often got errors when creating unstructured
meshes (mainly tetrahedras) over the particular
complex domain/volume. (Please take a look at the
attachment Geo file.)
There is a volume which contains some narrow holes.
I’m wondering if I need to divide it into some sub
domains…
Does anybody know the best way to avoid these errors?
thanks always,
kenji furui
Dept. Petroleum Engineering
The University of Texas at Austin
Do you Yahoo!?
Yahoo! News - Today’s headlines
Desc: skinm4_1vv.geo
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020914/74474685/attachment.obj
Dear GiD members,
Please use this geo file instead of the attachment in
my previous email.
I would like to have meshes under the following
conditions;
Element size on cavities (perforations); 0.04
(smaller is ok)
@Size transition; 0.6-0.8
thanks,
kenji (GiD ver7.1 user)
Do you Yahoo!?
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020914/20599ce9/attachment.obj
When there are problems in meshing, a possible procedure to
follow is this:
  • Use meshing-Mesh criteria-Mesh surfaces and select all surfaces.
  • Mesh again
  • Investigate the mesh shape, specially near the points where GiD
    exposes problems
In your particular case, the mesh over the thick cilinders is very
agly. Try to subdivide the associated surfaces with:
Geometry-Edit-Divide-Surfaces-Num divisions.
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de kenji furui
Enviado el: sábado, 14 de septiembre de 2002 17:19
Asunto: [GiDlist] mesh generation2
Dear GiD members,
my previous email.
conditions;
(smaller is ok)
thanks,
Do you Yahoo!?
Hi GiD team
I just would like to ask if GiD,the future Version,
can render the beam element as their properties
instead of single line but element section??
Like I beam, U beam, C beam and so on..with all
options of deformed shape and contour in post
processing???
Best Regards.
Do you Yahoo!?
In order for GiD to be able to render the beams
with his cross-section shape, it would be necessary
to create a way for defining the shapes. One possibility
would be to take advantage of the geometry defined
in the .sim file.
This can be a very interesting capability to be
added for next versions.
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de VSayako Willy
Enviado el: lunes, 16 de septiembre de 2002 5:06
Asunto: [GiDlist] Render beam element
Hi GiD team
processing???
Best Regards.
Do you Yahoo!?
