[GiDlist] 3D surface representation
I would like to know how a 3D surface can be represented using GID
For exemple the surface of a river.
Thank you
Abdou
You can create NURBS surfaces with several methods:
menu: Geometry-Create-Nurbs surface
  • By contour, create the surface interpolating the selected boundary lines
  • By a family “near-parallel” lines
  • By Points/By line points, selecting a cloud of points (the surface will be
    untrimmed, and not interpolate this points, only approximate them)
Other useful method is create from the copy window, by extruding some source
lines (by translation, rotation, sweep,…)
Other non-useful methods is:
Thank you so much Enrique but sorry,
my question was not explicit enough. I am simulating some kind of inundation
or dambreak. The preprocessing (mesh) is ok with GID , but at the
postprocessing step, I can only visualise the z-movement of the surface of
water using colors, View results- Contour Fill for exemple. Whereas I
want
a 3D animation.
If these explanation is not enough, please look at
http://www-rocq.inria.fr/bang/SWE/sur.damf.gif
to see what I really need to get.
Abdou Sene
- By contour, create the surface interpolating the selected boundary lines
- By a family “near-parallel” lines
- By Points/By line points, selecting a cloud of points (the surface will
be
source
From a cloud of points, can create a triangulation in Z=0 projection (this
option is only is availble from the right buttons)
escape escape escape meshing connectpoints createsurfaces
or
escape escape escape meshing connectpoints createelements
If you create triangle elements, you can after split them to approximate a
smooted shape (require the last 7.5.8b beta version)
menu: Meshing-Edit mesh-Split Elems-Triangle-Triangle
You can use directly this mesh, or can create a “surfmesh”, a
pseudo-surface
with the mesh shape that can be remeshed.
To create a surfmesh from a triangle selection use:
escape escape escape geometry create surfmesh selectmesh
Off course you can create the surfaces with an external CAD and import
them
(using IGES or other interchange format)
Sent: Thursday, May 19, 2005 4:19 PM
Subject: [GiDlist] 3D surface representation
Thank you
Abdou
Your solver must write a vector results with the nodes displacements in each
time step, and you can use this result to show the deformed mesh.
Open the View results window (menu: Window-View results)
And in the “main mesh”, select “Deformed”, and select the vector result to
use for the deformation. This vector can be a relative increment to add to
the original mesh, or the final position vector (must check “position
vector”)
Also can set the “factor scale”
Can see an animation of all steps from the Animate window (menu:
Windows-Animate), this film can be saved as mpg, avi or animated gif
Sent: Friday, May 20, 2005 1:04 PM
Subject: Re: [GiDlist] 3D surface representation
inundation
want
a 3D animation.
_http://www-rocq.inria.fr/bang/SWE/sur.damf.gif_
Abdou Sene
lines
will
be
source
(this
or
a
pseudo-surface
them
Thank you
Abdou
Thank you, it works well
Abdou
each
the original mesh, or the final position vector (must check "position
vector")
inundation
of
want
a 3D animation.
Abdou Sene
lines
will
be
source
(this
or
approximate
a
pseudo-surface
them
Thank you
Abdou
