# Failed to connect to server?
**URL:** <https://forum.gidsimulation.com/t/failed-to-connect-to-server/2584>\
**Category:** Installation\
**Created:** [March 11, 2021, 9:33am UTC](https://forum.gidsimulation.com/t/failed-to-connect-to-server/2584 "2021-03-11T09:33:08Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![PeytonBirch](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/p/f08c70/32.png) [@PeytonBirch](https://forum.gidsimulation.com/u/PeytonBirch)\
**Post date:** [March 11, 2021, 9:33am UTC](https://forum.gidsimulation.com/t/failed-to-connect-to-server/2584/1 "2021-03-11T09:33:08Z")
</div>
I just downloaded GID 13 and I would like to download Kratos through GID. Unfortunately, the connection to the server failed.
I found a similar topic on this forum: viewtopic.php?t=614 providing this solution:
"You can fix the problem for example with some of this ways:
- a) avoiding this ‘check for upgrades’ connection. To do it edit the file
scripts\ConfigureProgram.tcl and change
set ::GidPriv(ShowCheckNewVersion) 1
by
set ::GidPriv(ShowCheckNewVersion) 0
or you can also allow the connection changing your firewall configuration"
But the line set ::GidPriv(ShowCheckNewVersion) 0 isn’t in the file scripts\ConfigureProgram anymore.
I tried the second solution allowing every inbound and outbound rules for gid.exe but still doesn’t work.
Do you have a new solution? I am wondering which service or program GID is using when it tries to connect to the server (which might still be blocked by firewall).
Thank you for any assistance,
**Post date:** [March 12, 2021, 3:08pm UTC](https://forum.gidsimulation.com/t/failed-to-connect-to-server/2584/2 "2021-03-12T15:08:25Z")
</div>
Why download GiD 13?
Current versions of Kratos will require a more modern GiD version. Download current GiD 15.
and the problem of download probably won’t happen using GiD 15 because it is using https instead ftp protocol, that is problematic nowadays.
