Hello!
In my postprocessing using GiD 12.0.9, I create results by subtracting two increment steps for a scalar result data (error in the scalar solution field). But when I try to do it for a tensor data (order 2) I have following error:
found an error
while executing
“GiD_Result create {*}$res_dst”
(procedure “PCRApply” line 412)
invoked from within
“PCRApply”
invoked from within
".gid.wPostCrearResultado.but.apply invoke "
invoked from within
".gid.wPostCrearResultado.but.apply instate !disabled { .gid.wPostCrearResultado.but.apply invoke } "
invoked from within
“.gid.wPostCrearResultado.but.apply instate pressed { .gid.wPostCrearResultado.but.apply state !pressed; .gid.wPostCrearResultado.but.apply instate !di…”
(command bound to event)
Has this anything to do with the warning message when loading the .res file “Gauss point ‘gauss_points’ already defined.”?
Is there the possibility to create results for such tensors? Or is it possible to compare individual components of tensor for two different increment steps? Currently, in the options for Result selection, I am able to select only the tensor field and not the individual components.
Thank you in advance!
